Agilex 5 SLVS-400 Outputs
Since there are no feedback for this case, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, someone will be right with you.
- MarekK1 year ago
Hello AqidAyman_Intel,
There is no feedback from me for last twenty days, because you told me you are checking the problem with your team. So I expected you get back to me and give me any relevant information. If the half sentence "we recognized that MIPI TX usage will utilize SLVS buffers" was meant as a final solution, please state it clearly. It doesn't seem like solution to me. MIPI TX may use internally SLVS buffers(as far as I know this is never said directly in the doc), but it uses DPHY standard that is specified separately in the DS.
Marek
