Ariel50's avatar
Ariel50
7 days ago
Agilex 5 Power
Hello, I am using two A5EC043BB32AI4S devices and I am now planning their power rails. I have two questions.
  1. Is it possible to design one power supply (one regulator) per rail for both FPGASs
  2. There is a requirement in the PCB Design Guideline  User Guide for ‘Recommended VR Accuracy (% of Vnom)’ of ±0.5%.
    What is the meaning of this requirement?
    As I understand it, this refers to the Voltage accuracy (excluding line regulation and load regulation).
    This is a very strict requirement, and most power regulators cannot meet it.
    What is the practical meaning or impact of not meeting this requirement?
    In the datasheet, however, only a maximum value is specified, and it is usually around 3%.
    P.S:the requirement  of the  ±0.5%.are in  table 24 in PCB Design Guidelines (HSSI, EMIF,MIPI, True Differential, PDN) User Guide
1 Reply
  • Farabi's avatar
    Farabi
    1- Is it possible to design one power supply (one regulator) per rail for both FPGASs
    <ANS> Not recommended. The power is very critical for each devices. Might have insufficient power issue.
    2- There is a requirement in the PCB Design Guideline  User Guide for ‘Recommended VR Accuracy (% of Vnom)’ of ±0.5%.
    What is the practical meaning or impact of not meeting this requirement?In the datasheet, however, only a maximum value is specified, and it is usually around 3%.
    <ANS> The requirement is the VR output voltage swing must not exceed 0.5% for critical power rails. (not all power rails have this requirement).
    Critical power rails commonly monitored by POR(Power On Reset) circuitry.
    regards,
    Farabi
