Agilex 5 Power
1- Is it possible to design one power supply (one regulator) per rail for both FPGASs
<ANS> Not recommended. The power is very critical for each devices. Might have insufficient power issue.
2- There is a requirement in the PCB Design Guideline User Guide for ‘Recommended VR Accuracy (% of Vnom)’ of ±0.5%.
What is the meaning of this requirement?
As I understand it, this refers to the Voltage accuracy (excluding line regulation and load regulation).
This is a very strict requirement, and most power regulators cannot meet it.
What is the practical meaning or impact of not meeting this requirement?In the datasheet, however, only a maximum value is specified, and it is usually around 3%.
P.S:the requirement of the ±0.5%.are in table 24 in PCB Design Guidelines (HSSI, EMIF,MIPI, True Differential, PDN) User Guide
<ANS> The requirement is the VR output voltage swing must not exceed 0.5% for critical power rails. (not all power rails have this requirement).
Critical power rails commonly monitored by POR(Power On Reset) circuitry.
regards,
Farabi
- Ariel505 months ago
Hi, the requirement of ±0.5% is almost for all of the rails
- Farabi_Altera4 months ago
I have checked with internal team, the requirements are valid. They are critical power rails which needs 0.5% accuracy.
regards,
Farabi
