atex-tester
10 months agoAgilex 5 A5EC065BB32AE5SR0 issue
Hello I built a new board with A5EC065BB32AE5SR0 , I got a issue with the fabric. the FPGA is configurable, and Init done goes to high after configuration . I have a very simple verilog code wit...
atex-tester
10 months agoThe code is very simple, a PLL only
module test
input CLK_25MHZ_IN,
input DDR_REF_CLK0,
input DDR_REF_CLK1,
input DDR_REF_CLK2,
input DDR_REF_CLK3,
input AVSTX8W_CLK, //Avalon FIFO clock input
//GPIO Interface
inout [5:0] SYS_GPIO, //Sys GPIO 0 : as command output for cmd done
output [2:0] SYS_LED,
output DDR_B4_x4_DQ2,
output DDR_B4_x4_DQ6,
output DDR_1V8_IO0,
inout [6:0] GPIO
//assign DDR_B4_x4_DQ6 = AVSTX8W_CLK;
//assign DDR_B4_x4_DQ2 = CLK_25MHZ_IN;
wire sys_reset;
reset u0 (
.ninit_done (sys_reset) // output, width = 1, ninit_done.reset
wire sys_pll_locked;
wire nios_clk;
wire test_clk;
SYS_PLL sys_pll (
.refclk (AVSTX8W_CLK), // input, width = 1, refclk.clk
.locked (sys_pll_locked), // output, width = 1, locked.export
.rst (sys_reset), // input, width = 1, reset.reset
//.extclk_out (SYS_GPIO[1:0]),
.outclk_0 (nios_clk), // output, width = 1, outclk0.clk
.outclk_1 (test_clk), // output, width = 1, outclk1.clk
.outclk_2 () // output, width = 1, outclk2.clk
reg output_clk;
always@(posedge nios_clk) begin
output_clk <= ~ output_clk;
end
wire sys_rstn;
assign sys_rstn = sys_pll_locked & (~sys_reset);
assign SYS_LED[0] = sys_rstn? nios_clk : 1'bx;
assign SYS_LED[1] = sys_reset;
assign SYS_LED[2] = sys_pll_locked;
assign GPIO[0] = sys_rstn;
assign GPIO[1] = 1'b1;
assign GPIO[2] = CLK_25MHZ_IN;
assign GPIO[3] = 1'b1;
assign GPIO[4] = 1'b0;
assign GPIO[5] = 1'b1;
assign GPIO[6] = 1'b0;
endmodule
The voltage is shown on the screenshot above,
Temp sensor plot is shown above.
Any other files I can provide pls let me know
atex-tester
10 months agoThe led pin is gpio only.nothing is there and test point only. The nios clk is 100mhz, I am using oscilloscope to capture the wave form. A constant one is shown only. Pin assignment is correct. The pll locked is high but nothing came out from the pin
- ShengN_altera10 months ago
May i know any further update or concern from your side? Does the previous post helps?
You'll have to use pll clock source with low jitter check this link
Schematic can be downloaded from installer package link
For example premium dev kit, I set the location as below:
Signal tap result:
I use issp to toggle the reset:
issp u0 (.source (sys_reset) // output, width = 1, sources.source);
