atex-tester
10 months agoAgilex 5 A5EC065BB32AE5SR0 issue
Hello I built a new board with A5EC065BB32AE5SR0 , I got a issue with the fabric. the FPGA is configurable, and Init done goes to high after configuration . I have a very simple verilog code wit...
sstrell
10 months agoAre you trying to see this on a flashing LED or are you using a scope? You're not going to be able to see a multi MHz clock flash on an LED. What frequency is nios_clk? Have you made sure that the pin you assigned SYS_LED[0] in the Pin Planner is configured correctly (maybe needs a pull-up?)?
