MM-ATH's avatar
MM-ATH
1 year ago
Agilex 5 - HPS first - u-boot stuck if rebooting
I have problem after reboot of my system (reboot in linux console or press HPSrst button on AXE5-Eagle devboard), or if I fit fpgacore.rbf from u-boot twice, than boot from emmc stuck on:
Hit any key to stop autoboot:  0
2568192 bytes read in 124 ms (19.8 MiB/s)
...FPGA reconfiguration OK!
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr.uimg
2751 bytes read in 13 ms (206.1 KiB/s)
## Executing script at 81000000
crc32+ Trying to boot Linux from device mmc0
Found kernel in mmc0
First time (power-on or after press nconfig button on devboard AXE5-Eagle) it boots ok - succesfully continues to OS with:
5428330 bytes read in 245 ms (21.1 MiB/s)
## Loading kernel from FIT Image at 82000000 ...
   Using 'board-0' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel' kernel subimage
Can somebody help me to overcome this problem?
Martin
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi Martin
    From what I have gathered. There is no workaround available as it is a silicone bug.
    I assume if you were to use 25.1 it would be the same behavior too, but it is worth trying.
    This issue will be fixed in the B0 silicone of the Agilex5.
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Jingyang,Teh
