Agilex 5 - HPS first - u-boot stuck if rebooting
Hi
It seems like you would need to disable the F2H bridge in the Quartus Design too.
This is the current workaround and there is not fix currently as it is a silicon issue.
Jingyang, Teh
- MM-ATH1 year ago
we set FPGA to HPS subordinate to "Unused" in HPS Platform designer and behavior was same (that particular design was able to programm from linux as well as from u-boot).
We disabled interrupts and removed (unconnected) F2H components from connection matrix then and problem persists (this particular design can be programmed only from u-boot - please see AGILEX5 - HPS-first - timeout waiting for RECONFIG_COMPLETED ). If I reprogramm core.rbf more times, tipically second time LEDs driven from FPGA are not blinking, third reprogramm are blinking etc. I tried to boot to linux once with this core.rbf when leds was blinking and everything worked (it was maybe 5x reprogrammed core.rbf). But other time it hung when my linux application tried to use HPS2FPGA bridge (maybe after 3x times of reprogramm).
I have modified u-boot script and linux dtb to use hps2fpga bridge only in linux runtime, so I can boot to linux without programmed core.rbf.
Can we do something more? I am using Quartus 24.3.1 Build102 01/14/2025 with no patches.
Martin
