Agilex 3 PLL in Source Synchronous mode ?
Surprisingly, the compilation fails when we try to set a PLL in source synchronous mode in an Agilex 3, while this works as expected in Agilex 5. Compiles in "direct" mode. The pin assignment comes from the Atum A3-nano but we tried various dedicated clock inputs to no avail.
The error messages are a bit puzzling too (I think there are 11 PLLs in the A3CZ135BB18AE7S ) :
Error (14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 IOPLL(s)). Fix the errors described in the submessages, and then rerun the Fitter. The Intel FPGA Knowledge Database may also contain articles with information on how to resolve this periphery placement failure. Review the errors and then visit the Knowledge Database at https://www.intel.com/content/www/us/en/support/programmable/kdb-filter.html and search for this specific error message number.
Error (175001): The Fitter cannot place 1 IOPLL, which is within IOPLL IP pll_altera_iopll_2110_hws7ggy.
Info (14596): Information about the failing component(s):
Info (175028): The IOPLL name(s): u_pll|iopll_0|tennm_ph2_iopll
Error (16234): No legal location could be found out of 5 considered location(s). Reasons why each location could not be used are summarized below:
Error (23527): No route for refclk connection from "CLOCK0_50~CLUSTER" to "u_pll|iopll_0|tennm_ph2_iopll". Promote refclk to a global clock or use a dedicated IOPLL refclk pin. (4 locations affected)
Info (175029): IOPLL_X106_Y53_N346
Info (175029): IOPLL_X121_Y31_N846
Info (175029): IOPLL_X106_Y2_N346
Info (175029): IOPLL_X1_Y3_N346
Error (175006): There is no routing connectivity between the IOPLL and the IOPLL
Error (175022): The IOPLL could not be placed in any location to satisfy its connectivity requirements
Info (175029): 1 location affected
Info (175029): IOPLL_X121_Y6_N846
Error (15307): Cannot apply project assignments to the design due to illegal or conflicting assignments. Refer to the other messages for corrective action.
Error (16297): An error has occurred while trying to initialize the plan stage.
Error: Quartus Prime Fitter was unsuccessful. 8 errors, 11 warnings
This is very annoying for source synchronous interfaces (like RGMII).
Test case available indeed.
- BCuze
Can you answer the question please ? If the pin assignment cannot work, it means the Terasic Atum A3 kit GB Ethernet port cannot be used...
- BCuze
The test case QAR was attached to my original message (June 3rd 2026). 254 kB
I attach it again
- AqidAyman_Altera
Hi Bert,
Please check your inbox.
I have reach out to you r4egarding this.
Aqid
- BCuze
Letting Quartus select a suitable clock input pin does remove the error, sure...
But the problem is that we need actually to drive a PLL in Source synchronous mode by pin AT9 (1.8V LVCMOS).* This is not an option ! It is the Terasic Atum A3 nano board, and this scheme is the only way to reach timing convergence on the RGMII PHY (RxClock / RxData).
This scheme works on the Intel Agilex 5 kit.We cannot ask Terasic to redo the board layout.
What do you suggest ?* : note that the exact pin we need is AT9. We had to ask to get some schematics of the GBEth section.
The error message is :
- AqidAyman_Altera
I am able to get the design compiled successfully by letting Quartus selecting the clock input pin. You need to remove the I/O standard assigned first. Unfortunately, the compilation is failed if I assigned to the specific pin you mentioned (AT9).
Unless, if you promote it as a global clock, then the compilation is passed.
Below settings in .qsf in your project file:
set_location_assignment PIN_AT9 -to CLOCK0_50 -comment IOBANK_6E
set_instance_assignment -name IO_STANDARD "1.8-V LVCMOS" -to CLOCK0_50 -entity pll_bug
set_instance_assignment -name GLOBAL_SIGNAL ON -to CLOCK0_50Regards,
Aqid
- BCuze
Hi Aqid,
Did you test with the provided testcase ? Did you find an explanation ?
Thx in advance,
Bert
- AqidAyman_Altera
Hi Bert,
I did not see the test case you provided in this ticket. Is it possible for you to share it with me through private message?
I have initiated a message to you.
Aqid- BCuze
I used the "Attachment" button in the message editor and selected the file. (tried again on this answer).
And I didn't receive a message with the email address to use.
I dropped the QAR here too :
https://www.swisstransfer.com/d/447a9b69-3ca3-4ec6-8d5c-1a0562d2b834
BR
Bert
- AqidAyman_Altera
Thank you for reaching out to us.
This looks to me either a pin resources issue or hardware limitation issue. Can you share with me the use case design where I can replicate the error from my side? I need to check it first. Preferably in .QAR file.
If you need to share it privately, let me know.
Aqid
- BCuze
Should be attached
