Agilex 3 GTS PCIe IP missing
I have the feeling that you miss the whole picture... so let me summarize.
We try to migrate to a new chip generation (Agilex 5/3 with PCIE) and you tell me/us:
- no support in the future for SSGDMA (not "future", even current version 25.1.1 has no support; curiously, the IP got some technical tweaks together with the deprecation note
- no support for MCDMA for smaller devices (resource tweaks not possible)
- mSGDMA has no PCIE TLP support, not relevant (as the deprecation notes, it's only for SOC/MM)
Forget the "DMA" name, I just need PCIE TLP IP. The old CycloneV IP worked just fine with my design (I used indeed mSGDMA to feed into the tx interface, but I can use my own logic).
What option do I have (or what do you recommend) with PCIE TLP support and smaller devices?? Why are these devices available with PCIE but no IP support?
Gabriel
Hi @GabrielC ,
I understand how your feeling, but I am trying my best to assist you in either way.
Please accept sincere apologies if there is any inconvenience cause to you.
>> This information is available under the user guide 1. Product Discontinuance Notification
>> Passing the message with reason to ensure that you choosing the the best implementation for your future project
>> You can try to select a lower number of DMA channels
>> lower the data width for example 32 , 64 bit
>> control the amount of data transferred per dma burst
>> configure the "max burst size" to match your system's output correctly
>> those can be configure via the IP catalog.
>> I will pass this escalation back to our internal team.
>> If you really have a strict price concern, or device/ip selection issue, I would strongly suggest you to reach you to any of your local Distributor Field Application Engineer (DFAE). I believe they can help to address your concern.
Again, please accept my sincerely apologies for any inconvenience causing to you (if have).
I will raise up your concern to our development team, as user feedback always a top priority that we would take it seriously.
Let me know if there is anything else I can assist you more.
Wincent_Altera
- Wincent_Altera1 year ago
Hi Gabriel,
Is there anything else you think I can better assist you ?
Wincent
