Agilex 3 GTS PCIe IP missing
Hi @GabrielC ,
If I understand correctly, MCDMA is only "soft" IP. I would be optimistic to get it for A3...
Would it be possible to get some kind of "early beta" access? To be able to progress with my firmware design?
>> I understand your concern, That why I would suggest you to reach out to any of your cognizant Altera FAE/DFAE to check if the beta version is available or not
>> or you may try to submit your enquiry via https://www.altera.com/contact
Let me know if you have any further question.
Wincent
Hi @GabrielC ,
Is there anything else you think I can better assist you via this thread ?
Wincent
- GabrielC1 year ago
Hi Wincent,
As I wrote here ( community.intel.com/t5/Programmable-Devices/Agilex-3-GTS-PCIe-IP-missing/m-p/1716620#M101270 ), the focus changed to implementing/using on smaller devices (Agilex 5 is similar in price for the similar size, but no availability yet).
Should I open a new/dedicated thread?
Gabriel- Wincent_Altera1 year ago
Hi Gabriel,
Please accept my sincerely apology that I cannot help too much on this issue.
As mentioned the MCDMA for Agilex 3 ETA (subject to change) will only be available next year onwards.
If you really have a strict price concern, or device selection issue, I would strongly suggest you to reach you to any of your local Distributor Field Application Engineer (DFAE). I believe they can help to address your concern on both device and price selection.
Let me know if there is anything about the PCIe that I can better assist. I would happy to help out.
Wincent- GabrielC1 year ago
Hi Wincent,
You missed an important detail again...
I wrote explicitly, it fails for Agilex 5 (A5EC065BB32AE4S)!!
I chose a similar sized device; the price is also comparable, it could be a good option if it would also be available.But MMap (PIO) and DMA (D2H) is a must, and I need a solution...
Gabriel
