Paul36's avatar
Paul36
2 months ago
Agilex 3 A3CZ100BM16AE7S – 3.3 V HVIO input always reads HIGH
I am bringing up a new board using an Agilex 3 A3CZ100BM16AE7S and I am seeing a strange issue with the HVIO input path.
I am using Quartus Prime Pro 25.3.1.
The FPGA configures successfully through JTAG, FPGA logic is running, HVIO outputs work correctly, and inputs on non-HVIO banks also work correctly. However, the 3.3 V HVIO inputs always appear to be read as logic HIGH.
My current simple test uses:
Device: A3CZ100BM16AE7S
Quartus Prime Pro: 25.3.1
TP1: AF27
HVIO Bank: 5B
Direction: Input
I/O standard: 3.3-V LVCMOS
VCCIO_HVIO = 3.3 V
VCCPT_HVIO = 1.8 V
VCC/VCCP = 0.75 V
The FPGA power rails have been checked and appear correct.
A very simple test was first used:
TP1 is 3.3V HVIO pin and TP13 is non-HVIO pin
TP13 <= TP1;
When TP1 is physically LOW, TP13 still indicates that TP1 is HIGH.
I also tested:
TP13 <= not TP1;
With TP1 physically at 0 V, TP13 becomes LOW, which again indicates that the FPGA internally sees TP1 as logic 1.
I also tested the programmable weak pull-up/down on AF27 (HVIO pin).
With weak pull-up enabled:
TP1 ≈ 3.3 V (with the multi-meter)
With weak pull-down enabled:
TP1 ≈ 0 V (with the multi-meter)
The weak pull-up/down therefore physically changes the voltage at the FPGA pin correctly.
I then enabled the internal weak pull-up and added an external 1 kΩ resistor from TP1 to GND.
The measured TP1 voltage becomes approximately:
TP1 ≈ 150 mV
which is consistent with the internal ~20 kΩ pull-up and external 1 kΩ pull-down.
However, the FPGA still reads the input as HIGH.
Has anyone seen a similar issue with Agilex 3 HVIO input buffers, particularly with the A3CZ100BM16A device ?
Is there any additional HVIO input configuration, device setting, programming option, or known Quartus issue that I may be missing?
As far as I understand, a standard 3.3-V LVCMOS input on an HVIO bank should work directly without requiring any special input-enable configuration.
Any suggestions for further tests would be greatly appreciated.
Paul
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    Hi Paul,
    This is a well-documented hardware issue specific to Agilex 3 devices that include GTS transceivers. Your symptom matches it exactly. The issue affects the HVIO bank adjacent to the GTS transceiver bank and is related to specific power and pin connection conditions during board design. Refer here: Why do HVIO pins in an Agilex® 5 or Agilex® 3 FPGA HVIO bank appear to be non-functional after device configuration?
    Your A3CZ100BM16AE7S has 4 transceivers (XCVR: 4) https://docs.altera.com/v/u/docs/833123/agilextm-3-fpgas-and-socs-c-series-product-table , so the GTS transceiver bank is present and powered on your board. Bank 5B is the HVIO bank adjacent to the GTS transceiver bank, which is exactly the bank you're using (AF27, HVIO Bank 5B).
    The most likely root cause is the RCOMP pin for the GTS transceiver bank being left unconnected on your board. Check that pin first.
    Hope that gets you unblocked quickly!
    • Paul36's avatar
      Paul36
      Hi AqldAyman,
      Thanks for confirming that this matches the known RCOMP_GTS/HVIO issue.
      Unfortunately, on our current PCB the RCOMP_GTSL1A_P/N pins were intentionally left unrouted because the previous Agilex 3 pin connection guideline stated that RCOMP could be left floating when the GTS side was unused. Therefore, we have no accessible trace or pad where we can add the 499 Ω resistor as a manual rework.
      I understand the current documented options are:
      1.Keep VCCEHT_GTS = 1.8 V and VCCERT_GTS = 1.0 V, and connect RCOMP_GTS_P to RCOMP_GTS_N using 499 Ω ±0.1%.
      2.If the GTS is completely unused, tie both VCCEHT_GTS and VCCERT_GTS to GND and allow RCOMP to float.
      On our current PCB, option 2 is also difficult because VCCERT_GTS shares the 1.0-V supply with VCCH_SDM, which must remain powered at 1.0 V. We cannot isolate the VCCERT_GTS pins from that rail without a PCB re-spin.
      Is there any third supported workaround for an already-fabricated board, such as a Quartus/device setting that fully powers down the GTS while its external supply pins remain powered, or any other supported RCOMP configuration?
      If not, we will update the next PCB revision to add the 499 Ω RCOMP resistor.
      Paul
        AqidAyman_Altera
        Paul,
        I understand the bind you're in.
        And I have to be straightforward that I cannot find any third supported configuration in the available documentation that covers the specific combination of: RCOMP floating + VCCEHT_GTS/VCCERT_GTS externally powered + VCCH_SDM sharing the 1.0 V rail.
        Sorry I can't give you a cleaner answer for the existing boards. The documentation simply doesn't provide a supported escape for this combination.
