Agilex 3 A3CZ100BM16AE7S – 3.3 V HVIO input always reads HIGH
Hi Paul,
This is a well-documented hardware issue specific to Agilex 3 devices that include GTS transceivers. Your symptom matches it exactly. The issue affects the HVIO bank adjacent to the GTS transceiver bank and is related to specific power and pin connection conditions during board design. Refer here: Why do HVIO pins in an Agilex® 5 or Agilex® 3 FPGA HVIO bank appear to be non-functional after device configuration?
Your A3CZ100BM16AE7S has 4 transceivers (XCVR: 4) https://docs.altera.com/v/u/docs/833123/agilextm-3-fpgas-and-socs-c-series-product-table , so the GTS transceiver bank is present and powered on your board. Bank 5B is the HVIO bank adjacent to the GTS transceiver bank, which is exactly the bank you're using (AF27, HVIO Bank 5B).
The most likely root cause is the RCOMP pin for the GTS transceiver bank being left unconnected on your board. Check that pin first.
Hope that gets you unblocked quickly!
Hi AqldAyman,
Thanks for confirming that this matches the known RCOMP_GTS/HVIO issue.
Unfortunately, on our current PCB the RCOMP_GTSL1A_P/N pins were intentionally left unrouted because the previous Agilex 3 pin connection guideline stated that RCOMP could be left floating when the GTS side was unused. Therefore, we have no accessible trace or pad where we can add the 499 Ω resistor as a manual rework.
I understand the current documented options are:
1.Keep VCCEHT_GTS = 1.8 V and VCCERT_GTS = 1.0 V, and connect RCOMP_GTS_P to RCOMP_GTS_N using 499 Ω ±0.1%.
2.If the GTS is completely unused, tie both VCCEHT_GTS and VCCERT_GTS to GND and allow RCOMP to float.
On our current PCB, option 2 is also difficult because VCCERT_GTS shares the 1.0-V supply with VCCH_SDM, which must remain powered at 1.0 V. We cannot isolate the VCCERT_GTS pins from that rail without a PCB re-spin.
Is there any third supported workaround for an already-fabricated board, such as a Quartus/device setting that fully powers down the GTS while its external supply pins remain powered, or any other supported RCOMP configuration?
If not, we will update the next PCB revision to add the 499 Ω RCOMP resistor.
Paul
- AqidAyman_Altera2 months ago
Paul,
I understand the bind you're in.
And I have to be straightforward that I cannot find any third supported configuration in the available documentation that covers the specific combination of: RCOMP floating + VCCEHT_GTS/VCCERT_GTS externally powered + VCCH_SDM sharing the 1.0 V rail.
Sorry I can't give you a cleaner answer for the existing boards. The documentation simply doesn't provide a supported escape for this combination.
