Agilex 3 A3CZ100BM16AE7S – 3.3 V HVIO input always reads HIGH
I am bringing up a new board using an Agilex 3 A3CZ100BM16AE7S and I am seeing a strange issue with the HVIO input path.
I am using Quartus Prime Pro 25.3.1.
The FPGA configures successfully through JTAG, FPGA logic is running, HVIO outputs work correctly, and inputs on non-HVIO banks also work correctly. However, the 3.3 V HVIO inputs always appear to be read as logic HIGH.
My current simple test uses:
Device: A3CZ100BM16AE7S
Quartus Prime Pro: 25.3.1
TP1: AF27
HVIO Bank: 5B
Direction: Input
I/O standard: 3.3-V LVCMOS
VCCIO_HVIO = 3.3 V
VCCPT_HVIO = 1.8 V
VCC/VCCP = 0.75 V
The FPGA power rails have been checked and appear correct.
A very simple test was first used:
TP1 is 3.3V HVIO pin and TP13 is non-HVIO pin
TP13 <= TP1;
When TP1 is physically LOW, TP13 still indicates that TP1 is HIGH.
I also tested:
TP13 <= not TP1;
With TP1 physically at 0 V, TP13 becomes LOW, which again indicates that the FPGA internally sees TP1 as logic 1.
I also tested the programmable weak pull-up/down on AF27 (HVIO pin).
With weak pull-up enabled:
TP1 ≈ 3.3 V (with the multi-meter)
With weak pull-down enabled:
TP1 ≈ 0 V (with the multi-meter)
The weak pull-up/down therefore physically changes the voltage at the FPGA pin correctly.
I then enabled the internal weak pull-up and added an external 1 kΩ resistor from TP1 to GND.
The measured TP1 voltage becomes approximately:
TP1 ≈ 150 mV
which is consistent with the internal ~20 kΩ pull-up and external 1 kΩ pull-down.
However, the FPGA still reads the input as HIGH.
Has anyone seen a similar issue with Agilex 3 HVIO input buffers, particularly with the A3CZ100BM16A device ?
Is there any additional HVIO input configuration, device setting, programming option, or known Quartus issue that I may be missing?
As far as I understand, a standard 3.3-V LVCMOS input on an HVIO bank should work directly without requiring any special input-enable configuration.
Any suggestions for further tests would be greatly appreciated.
Paul
1 Reply
- AqidAyman_Altera
Hi Paul,
This is a well-documented hardware issue specific to Agilex 3 devices that include GTS transceivers. Your symptom matches it exactly. The issue affects the HVIO bank adjacent to the GTS transceiver bank and is related to specific power and pin connection conditions during board design. Refer here: Why do HVIO pins in an Agilex® 5 or Agilex® 3 FPGA HVIO bank appear to be non-functional after device configuration?
Your A3CZ100BM16AE7S has 4 transceivers (XCVR: 4) https://docs.altera.com/v/u/docs/833123/agilextm-3-fpgas-and-socs-c-series-product-table , so the GTS transceiver bank is present and powered on your board. Bank 5B is the HVIO bank adjacent to the GTS transceiver bank, which is exactly the bank you're using (AF27, HVIO Bank 5B).
The most likely root cause is the RCOMP pin for the GTS transceiver bank being left unconnected on your board. Check that pin first.
Hope that gets you unblocked quickly!
