Agilex™ 7 F-Series and I-Series ES Device Errata and User Guidelines
Hello !
Please help us to get this errata document.
We got Agilex-7 I-Series Kit ES1 6xF-Tile (DK-SI-AGI040FES) with AGIC040R39A2E2VR0 device and need errata document for ES1 device to departure from kit package sample designs with clear understanding ES1 device limitation while building own designs for the device in the kit.
All applications through Intel access gets all time denials without any explanations, links and even FAE contact information. Wasted $15k on this kit and cannot get any support, terrible experience with Intel.
Best regards, Sam
- sstrell
I don't see an errata document, but just making sure you've been here:
https://www.altera.com/products/devkit/po-3015/agilex-7-fpga-i-series-transceiver-development-kit-6x-f-tile-es
- CyberSam035
Link to errata datasheet is on Agilex™ 7 F-Series and I-Series Known Issue List document (i attached screenshot):
https://docs.altera.com/r/docs/683584/current/agilextm-7-f-series-and-i-series-known-issue-list/about-this-document
This is link to Errata. But I wasn't able to obtain permission through Intel process despite many attempts
https://cdrdv2.intel.com/v1/dl/getContent/612877?explicitVersion=true
This information was clearly available in older datasheet before Altera separated from Intel (still avaiable on Mouser and Digikey kits page)
https://www.mouser.com/pdfDocs/ug-agilex-i-fpga-devl-kit-683288-6772523.pdf
- CyberSam035
This ES errata document is mentioned in Agilex™ 7 F-Series and I-Series Known Issue List.
Here is screenshotIts also still available in old I-series datasheets that are hosted on Mouser and Digikey: https://www.mouser.com/pdfDocs/ug-agilex-i-fpga-devl-kit-683288-6772523.pdf
Here is screen shot:
This is link to get datasheet but I cannot get permission to it:https://cdrdv2.intel.com/v1/dl/getContent/612877?explicitVersion=true
!!! AND PLEASE DO NOT erase may answers !!!! - CyberSam035
- CyberSam035
!!! DO NOT DELETE MY QUESTIONS !!!! - CyberSam035
- CyberSam035
Its also still available in old I-series datasheets that are hosted on Mouser and Digikey: https://www.mouser.com/pdfDocs/ug-agilex-i-fpga-devl-kit-683288-6772523.pdfhis is link to get datasheet but I cannot get permission to it:
- CyberSam035
- CyberSam035
This is what I need but Intel don't provides permission despite filling all forms multiple times.
Wasted $15 K for kit and got terrible support refusing to help with kit
- tom2602
Hi Sam,
We have been working to migrate documents from the Intel website to the Altera website, so some of the Intel links may no longer work. For the document you are asking about, I do see it available on the Altera website. I believe you will need to register with MyAltera to gain access.
Please give the link a try after you have registered with MyAltera. You should see the MyAltera in the upper right corner of the main Altera.com page.
Tom
- CyberSam035
Tom,
Thank you so much for clarification
Sam
