Yes, there are differences in the steps.
- The ATF steps are skipped
- Buildroot is used to build everything, so toolchain, u-boot, linux, etc
- the steps for building the SD card image are also different. Our image is created using the genimage tool
The memory was reduced by adding the 'mem=3584M' to the u-boot bootargs that get passed to Linux.
I will add the boot log for the AGFB014R24A2E2VR0 board at a later date as I don't have that on hand.
I've attached the boot log for the AGFB014R24B2E3V board booting successfully with reduced memory.
Thanks!
I've attached the boot log for the AGFB014R24A2E2VR0 board booting successfully with reduced memory.
The build dates are different, since I had to regenerate the .jic for the QSPI, and the eMMC image had been rebuilt with some unrelated file changes in the rootFS. The U-boot and kernel settings were unchanged.
Thanks!
