AGFB014R24B2E2EV : Evaluation board not booting with eMMC memory
Dear Experts,
We received the new AGFB014R24B2E2EV Eval board when we switched on the board the HPS Linux running was noticed on UART when Out of box experience daughter card was plugged in. No prints are seen when the NAND daughter card is plugged in and the eMMC flash boot option is chosen.
Please help.
- EBERLAZARE_I_Intel
Are you still having issues? Any update from your side?
Yea, I am having issues as well with the git clone repo, let me check on our side on this issue. By default, before you run bitbake, you may change/set your settings/configs in then run the bitbake to take affect.
What is your Linux environment and version used?
Just an update, I am still working on it.
Thanks for the update, let me check this. Might take a few days, I need to validate the steps on my side.
So is the eMMC flash is now booting using all default settings?
I guess, may I know the steps that you run to build the customer RFS?
- MK_086
Yes, eMMC flash image is booting.
We are trying to follow the instructions for custom RFS:
Customizing/modify the Rootfs recipe in: recipes-images/poky/gsrd-console-image.bb
- add your c file in recipes-images/poky/files (mkdir)
- In recipes-images/poky/gsrd-console-image.bb, add the followings
- FILESEXTRAPATHS:prepend := "${THISDIR}/files:"
- SRC_URI:append="<CFILE>"
- Add this under nfs_rootfs() function:
- cp ${WORKDIR}/<CFILE> ${IMAGE_ROOTFS}/home/root
- Run bitbake_build and see if the c program in present in the compiled rfs by launching it on the board
Not seen the 'recipes-images/poky/gsrd-console-image.bb' files in the GSRD setup. Is it possible to share full path of it?
Also,
As per the website - https://www.rocketboards.org/foswiki/Projects/AgilexSoCWithEMMCStorageOnHPS#Writing_the_eMMC_Image there is a seperate option to Build Rootfs:
-Any steps available to add our files to this rootfs compilation?
Okay with the jumper settings set to eMMC, are you able to do the same steps as you did with the NAND using ARM DS debugger? And run the following steps:
- MK_086
eMMC U-Boot, Linux is working when we program through ARM DS. However, custom RFS is not getting generated & program.
Just to check again, when you mention select eMMC as boot option do you mean setting the jumper on the daughter card?
Check the jumper Settings (for eMMC):
https://www.rocketboards.org/foswiki/Projects/AgilexSoCWithEMMCStorageOnHPS#Prerequisites
Can you confirm that the eMMC is active with above pins setup? And that still no prints?
- MK_086
We verified the jumper settings as per manual but still no prints observed on the UART.Thanks
