Nathen
4 years agoAdequate Replacement for EPM7064STC44-5
I have a project that utilizes the EPM7064STC44-5 chip, however, Intel has obsoleted this part. Do you know what part would be a good alternative to this chip that Intel supports and has the s...
- 4 years ago
There is always the MicroChip/Atmel ATF1504 series part as well.
Still in active production, is a drop in replacement for the EPM7000S series parts 7032/7064/7128.
They even have a tool (POF2JED) that will convert an existing Altera .POF file into the Atmel .JED file to program their part.
I have dropped numerous ATF1504AS parts into existing EPM7064S based boards. Fully functional compatible in my experience.
Nathen
4 years agoThat is a great idea! I will look into that. Thank you so much for suggesting the ATF1504. I may still run into timing issues and part availability simply due to the current times with the chip shortage, but that sounds like good replacement and a good place to start.
