9 years agoAdding non-addressable memory causes Downloading ELF Process Failed message
I systematically removed components and narrowed my problem to just one: a 64kB 64-bit On-chip ram that is NOT accessed/connected to the Nios II. I developed a subsytem that exclusively uses that me...
9 years agoWell, seems I found my problem. I was definitely failing timing. I'm still working out timing in the whole design, but the 64KB of on-chip memory added many cycles worth of slack for some reason; all default tests failed. I reduced to 5KB, and I am now off time by 5ns. The design at least loads, but I need to add a few pipelines in my design.
For anyone else who has this problem, ensure you meet timing!!
