15 years agoAdding Hex numbers
Hi, Does anyone know how can I add Hex numbers inside the process (VHDL)? For instance, I want to add x"55" + x"55" but if I'll write " x"55" or x"55" " the answer will be x"55" (the answer sh...
15 years ago --- Quote Start --- Hi, Does anyone know how can I add Hex numbers inside the process (VHDL)? For instance, I want to add x"55" + x"55" but if I'll write " x"55" or x"55" " the answer will be x"55" (the answer should be x"AA"). Idan --- Quote End --- Of course x"55" or x"55" is x"55" as this is a binary or, used on the vector bitwise. Addition in VHDL (one of the reasons I prefer Verilog over HDL) requires type conversions as it has quite a strict type checking: result <= std_logic_vector(unsigned(x"55") + unsigned(x"55")); Also please note that unless you do know exactly what you do an addition of two vectors with N and M bits require the result to be max(N,M) + 1 bit wide.
