14 years agoAdding and resizing in one step
Hi, Is there a way to add two unsigned numbers and extract only the x most significant bits from it in one step? I want something like this: sum <= resize(number1 + number2,4) In...
14 years ago --- Quote Start --- I have two problems with this construct - it doesn't refer to a defined VHDL syntax as far as I'm aware of - it leaves sum unconnected in Quartus V9.0, without generating an error --- Quote End --- I verified it in 12.0 in the RTL-viewer. Both constructs generated the same 'schematic'. I almost sure it will also work in 9.1 as I have used similar constructs in 9.1-based projects. I have never looked at the offical VHDL specification and I am not a language expert but let's elaborate: if we write
sum <= n1 + n2 ; we conclude that the sum of the two unsigned vectors is assigned to an unsigned vector. The VHDL compiler knows how to do this. Internally the compiler may represent the result of 'n1 + n2' in any format it thinks suited, but it will convert it into the unsigned representation of the LHS. Now consider a function --- Quote Start --- func( par : xxx) return unsigned ... --- Quote End --- we can do the following: --- Quote Start --- sum <= func( n1 + n2 ) --- Quote End --- assuming func handles the type of 'n1 + n2'. A function returns an (RHS) object of the specified type and as such we can write the following: --- Quote Start --- sum <= func(n1 + n2)(7 downto 4) ; --- Quote End --- A typecast is a kind of special function, so we can replace the function func() with the typecast unsigned() resulting in sum <= unsigned(n1 + n2)(7 downto 4) ; So we can save some typing and can do with less 'intermediate' signals cluttering up the file. It also works with the dot-operator for functions returning a record type. You may have to enable VHDL 2008 support, I always do ...
