16 years agoAdd instructions in the processor NIOS
Hi everybody!! I wonder if anyone knows how to put instructions in the processor NIOS...These instructions are created by me. I tried to follow the manual but is not working. I also tried to ...
16 years agodo you mean custom instructions ?
open your project with the sopc builder have a look at menue -> tools -> options change to the IP search path make shure there is a path listed that contains your custom ip custom ips will not be visible where normals ips are in your component library on the left side instead double clic on your nios core go to last tab Custom Instructions your custom ip will be available on the left side, highlight it and add it now you should see it on the right side with its opcode extension close the nios core window regenerate the sopc recompile your fpga now your design has the custom ip functionality if you use the ide, just recompile your application at it should now know your custom ip
