16 years ago
ADC acquisition with FPGA
I´m trying to interface an ADC9254 (from ti) converter in VHDL with board DSP Development Board for Stratix II Edition, in order to do an acquisition for signal, but i´m new in this type of design language.
To be clear , the purpose of this project is to locate defects by reflectometry in a wired electric network, so using FPGA i send signal from DAC, after this i should measure the reflected signal and treat it with the ADC.
so i need some help. I´m interested in the vhdl code if it would be possible. Thank you very much.
    --- Quote Start ---
    VHDL wise, Interfacing the FPGA with the ADC is, in itself, quite trivial: use the ADC's Data Output Clock to register the ADC's Data Output signals.
    --- Quote End ---
    And use dedicated clock input pin at same io bank with data bus.
    there's no ADC9254 from TI. I presume you meant AD9254 from Analog Devices.
    You'll also need to set some ADC parameters. IIRC, most of them can be set through configuration pin. In a worse case scenario, you'll need a small state machine to implement the SPI protocol.
    i can't use PLL , it's should do another function
    i must use just a dac and adc to measure the reflected signal
    for the dac i generate a pulse wich is the incident signal , now i have to do the acquisition with adc (this one is connected to the dac)
    thank you for your help
    I can't find this ADC. But looks like you can clock this ADC from PLL in Altera and use other clock (shifted) of this PLL for clock input data.
