13 years agoAccessing HPS Pins
Hello, I know I can route HPS pins to the FPGA side but is it possible to do the opposite, route FPGA side logic to HPS part pins? Thank you
12 years ago --- Quote Start --- When you use the EMAC HPS I/O pins as loaner I/O don't expect them to have to have many features. As you can see from the output there is no altddio atom in the HPS I/O. Loaner I/O do not have double data rate logic, delay chains, registers, etc... in them. Loaner I/O are intended to be use for low speed connectivity since the I/O is limited in functionality and the delay between two adjacent loaner I/O is much more than what you are accustom to with the regular FPGA I/O. --- Quote End --- Thanks BadOmen.
