14 years agoAccess Violation error: How to solve?
Hello every body,
I was trying to complie the code on Quartus 11.1 (with sp1 added) & got following error during compliation. Please let me know how to resolve this. Thanks in advance! Regards, sam_fpga *** Fatal Error: Access Violation at 0X73E5F7AE Module: quartus_map.exe Lock in use: 4 Stack Trace: 0x5f7ad: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::substr + 0x126d (DgApi) 0x5c0fe: DGAPI_GetPlugInContext + 0x965e (DgApi) 0x36969: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> > + 0x5909 (DgApi) 0x3882a: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> > + 0xe6a (DgApi) 0x38b87: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> > + 0x11c7 (DgApi) 0x38e4e: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> > + 0x148e (DgApi) 0x3a794: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> > + 0x2dd4 (DgApi) 0x28b4c: rename + 0x10 (MSVCR90) 0x3f9a: PDB_SEGMENT_WRITER::commit + 0x25a (DB_PDB) 0x2747: pdb_write_ptr + 0xa7 (DB_PDB) 0x2edd0: TIS_DB_MANAGER::get_instance + 0x19d0 (tsm_tis) 0x2e991: TIS_DB_MANAGER::get_instance + 0x1591 (tsm_tis) 0x2c40c: TIS_ATOM_CALCULATOR::get_io_voltage + 0x3cc (tsm_tis) 0x17ea9c: TIS_TGX_INFO_MANAGER::get_dtm_node_enum_from_cdb_re_type + 0x16cc (tsm_tis) 0x17eb19: TIS_TGX_INFO_MANAGER::get_dtm_node_enum_from_cdb_re_type + 0x1749 (tsm_tis) 0x3999f: RtlQueryEnvironmentVariable + 0x240 (ntdll) 0x4d6b9: LdrShutdownProcess + 0x140 (ntdll) 0x4d55b: RtlExitUserProcess + 0x73 (ntdll) 0x17362: ExitProcess + 0x14 (kernel32) 0x221cb: _amsg_exit + 0x74 (MSVCR90) 0x22410: _get_pgmptr + 0x195 (MSVCR90) 0x22465: exit + 0x10 (MSVCR90) 0x25ebb: __ftol2 + 0x1e5 (quartus_map) 0x13676: BaseThreadInitThunk + 0x11 (kernel32) 0x39f41: RtlInitializeExceptionChain + 0x62 (ntdll) 0x39f14: RtlInitializeExceptionChain + 0x35 (ntdll) End-trace Quartus II 32-bit Version 11.1 Build 173 11/01/2011 SJ Full Version5 Replies
try deleting the db and incremental_db directories
If that doesnt work - raise a support request with altera mysupport, and you'll probably have to drop back a version if they cant find the issue. - Altera_Forum
Hi Tricky, Thanks for reply. But the solution that you provided didn't worked. I had also installed service pack 2. But still again getting the same error.
then like I said - try and earlier version and raise a mysupport request with altera - there isnt a lot we can do here. Altera can try and find the crash to fix it in the next version, or identify what you are doing to cause the crash.
once in a while there's enough of a bread crumb in an IE go to on...
"get_io_voltage" is mentioned in yours. try taking a look at the I/O assignments, maybe comment all of them out in the .qsf (use# ) - Altera_Forum
if you're using a V family definitely try sp2
