About the number of PLL outputs (CYCLONE5)
- 5 years ago
The 'nine clock output signals for the Cyclone V devices' in Altera PLL IP core corresponds to
C output counters -> 9
in the Cyclone V handbook. These are the clocks generated from the PLL.
The Dedicated external clock outputs represent the FPLL_<#>_CLKOUT pins on the device. You can connect any of the C output counters to external clock outputs. Refer 4.2.6. PLL External Clock I/O Pins of Device Handbook.
There are dedicated clock output pins associated with each corner fractional PLL.
So the main difference is that C counters are PLL outputs (internal to FPGA) whereas CLKOUT pins are device outputs (available external to the FPGA).
It's referring to what pins are dedicated clock output pins of the device. You can have more clocks internal to the device that are not sent out the dedicated clock output pins.
- testp5 years ago
Thank you for your reply.
I saw the answer, but I didn't understand.Device to be used: 5CEBA7F23C7N
I am thinking of using the above device.
From the contents of the answer
When the PLL is created with IP, 9 CLKs can be branched inside the FPGA,
FPLL_ [BL, BR, TL, TR] _CLKOUT0 (eg AH11) etc.
If you want to output to the CLK output dedicated pin
I understand that you can assign up to 2 singles.One question comes up here.
The CYCLONE5 overview (see below) states that the maximum number of PLLs is 7.
I recognize this 7 as the number of pins that can be output to the outside.Source: CV-51001
See also: Table 4. Maximum Resource Counts for Cyclone V E Devices
Item: PLLI checked all the packages of CYCLONE5, but
Looking at the F31 type, the following eight pins are dedicated to CLK output.FPLL_BL_CLKOUT0, FPLL_BL_CLKOUTp, FPLL_BL_FB (AH11)
FPLL_BL_CLKOUT1, FPLL_BL_CLKOUTn (AH12)
FPLL_BR_CLKOUT0, FPLL_BR_CLKOUTp, FPLL_BR_FB (Y30)
FPLL_BR_CLKOUT1, FPLL_BR_CLKOUTn (W30)
FPLL_TL_CLKOUT0, FPLL_TL_CLKOUTp, FPLL_TL_FB (F9)
FPLL_TL_CLKOUT1, FPLL_TL_CLKOUTn (E10)
FPLL_TR_CLKOUT0, FPLL_TR_CLKOUTp, FPLL_TR_FB (M29)
FPLL_TR_CLKOUT1, FPLL_TR_CLKOUTn (N30)It looks like there is a difference from PLL7 mentioned in the overview,
What does PLL 7 in the overview mean?
