16 years agoabout if
hello,
do you know how to terminate an "if" instruction? the instructions are repeating over and over again and i don't want to repeat.I need a break terminal or something like that.I search on the net but it doesn't work.If you know...please help. Best regards, tastax4 Replies
thx a lot! your example was very helpfull for me and it works for my project!
It will be executed every time the clock comes.
The only way to avoid it is to remember that it was already ran once: logic once = 1'b0; always @ (posedge clk) begin if (once == 1'b0) begin // insert your code here once <= 1'b1; // remember that it already ran once end end - Altera_Forum
is in verilog and is in a clocked always block. How can i execute the if instruction just once?
if in C on a Nios ?
if in VHDL ? if in Verilog ? Is the "if" in HDL and is it inside a clocked process/always block ?
