8 years ago
About booting an Image
How to generate preloader ?
Where can we get BSP editor?
Could someone eplease explain about it?
thanks
    Hi Sasi,
    Go to altera download page and download the embedded design suite for your quartus version. Start an embedded shell.Here you can call the bsp-editor.
    Hi Sasi,
    --- Quote Start ---
    --- Quote End ---
    The Cyclone V and Arria V Preloader build flow
    • Copies the generic preloader source code into <bsp directory>/ubootsocfpga
    • Copies the generated BSP files and hardware handoff files to the source directory in <bsp_directory /uboot-socfpga/board/altera/socfpga _<device>
    • Configures the compiler tools to target an SoC FPGA
    • Compiles the source files in <bsp directory>/uboot-socfpga with the userspecified cross compiler (specified in the BSP settings) and stores the generated preloader binary files in <bsp_directory>/uboot - socfpga/spl
    • Converts the preloader binary file to a preloader image, <bsp_directory>/preloader- mkpimage.bin, with the mkpimage tool
    The makefile contains the following targets:
    • make all – compiles the preloader
    • make clean – deletes preloader-mkpimage.bin from the <bsp directory>
    • make clean-all – deletes <bsp directory>, including the source files in the
    directory
    --- Quote Start ---
    --- Quote End ---
    BSP settings, which can be accessed from either the Graphical User Interface application (bsp-editor) or
    From the command line tools (bsp-create-settings, bsp-update-settings, bsp-query-settings).
    For detailed steps refer below link.
    https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_soc_eds.pdf (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_soc_eds.pdf)
    Anand Raj Shankar
