8 years agoAbout booting an Image
How to generate preloader ? Where can we get BSP editor? Could someone eplease explain about it? thanks
8 years agoHi Sasi,
--- Quote Start --- How to generate preloader ? --- Quote End --- The Cyclone V and Arria V Preloader build flow • Copies the generic preloader source code into <bsp directory>/ubootsocfpga • Copies the generated BSP files and hardware handoff files to the source directory in <bsp_directory /uboot-socfpga/board/altera/socfpga _<device> • Configures the compiler tools to target an SoC FPGA • Compiles the source files in <bsp directory>/uboot-socfpga with the userspecified cross compiler (specified in the BSP settings) and stores the generated preloader binary files in <bsp_directory>/uboot - socfpga/spl • Converts the preloader binary file to a preloader image, <bsp_directory>/preloader- mkpimage.bin, with the mkpimage tool The makefile contains the following targets: • make all – compiles the preloader • make clean – deletes preloader-mkpimage.bin from the <bsp directory> • make clean-all – deletes <bsp directory>, including the source files in the directory --- Quote Start --- Where can we get BSP editor? --- Quote End --- BSP settings, which can be accessed from either the Graphical User Interface application (bsp-editor) or From the command line tools (bsp-create-settings, bsp-update-settings, bsp-query-settings). For detailed steps refer below link. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_soc_eds.pdf (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_soc_eds.pdf) Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
