xingyunzhidi
1 year agoA question about generating a PCIe R-tile design example
I would like to generate a PCIe R-tile design example for MCIO pins. However, I am unable to select the interface type in the design example generation interface. Would it be acceptable to modify the...
Wincent_Altera
1 year agoHi,
For PCIe gen 5 R-tile, you can generate from our Quartus IP Catalog.
If you need detail about the system level implementation , you may refer to
But , those are not supporting MCIO, user is advise to customize the pin in order to support MCIO implementation.
Detail about the PIN, you may refer to
- Board schematic DK-DEV-AGI027R1BES
- Connector detail A.4. MCIO Connector
Wincent_Altera
