17 years ago
A question about generate pulse signal between different clock zone
I need to generate a 124M pulse from a 52M pulse. Restrited by the pipeline stages, I use this method:
always @ ( ... posedge clk_124 )
sig124 <= P52;
end
p124 <= P52 & (~P124);
end
I wonder if this method is safe? :D
    --- Quote Start ---
    sig124 <= P52;
    end
    end
    --- Quote End ---
    Shoudn't the second process be
    P124 <= P52 & (~sig124 );
    end
    i.e. you are generating a pulse of 1 clk_124 period when P52 is ''1' and the last value of P52 ( Stored in sig124 FlipFlop) is 0, in effect a rising edge detector.
    Otherwise it should be "safe" assuming P52 is synchronous to clk_124. If it isn't you will need to add extra pipeline flipflops to reduce the effects of metastability in clock domain crossing i.e
    sig124_L1 <= P52;
    sig124_L2 <= sig124_L1;
    sig124_L3 <= sig124_L2;
    end
    p124 <= sig124_L2 & (~sig124_L3);
    end
    --- Quote Start ---
    sig124 <= P52;
    end
    end
    --- Quote End ---
    what is the purpose of sig124? Should be "p124" the same signal as "P124" ?Be aware that verilog is case sensitive.
