17 years agoA question about generate pulse signal between different clock zone
I need to generate a 124M pulse from a 52M pulse. Restrited by the pipeline stages, I use this method: always @ ( ... posedge clk_124 ) ... sig124 <= P52; end always @ ( ... p...
17 years ago --- Quote Start --- I need to generate a 124M pulse from a 52M pulse. Restrited by the pipeline stages, I use this method: always @ ( ... posedge clk_124 ) ... sig124 <= P52; end always @ ( ... posedge clk_124 ) ... p124 <= P52 & (~P124); end I wonder if this method is safe? :D --- Quote End --- Hi, what is the purpose of sig124? Should be "p124" the same signal as "P124" ?Be aware that verilog is case sensitive.
