18 years agoa problem about fir design using dspbuilder
I want to design a fir filter with dspbuilder,but the result is not correct,I'm very confused. The following are the parameter I want to reach: The source signal is sythesis of a sin signal which frequency is 200HZ and a sin signal which frequency is 5000HZ.I want to design a low filter.so that I want to see only the 200HZ signal after the sounce passed the filter.The sample frequency is 20000HZ. AP:1db AS:30db I use the kaiser window with beta=0.5 I will show the whole design with my .mdl file,expect your response as soon as possible! Thanks for any help. I'm a freshman in filter design.2 Replies
how did u do it can you tell me please
The problem has been solved by myself,thank you all the same!
