17 years ago7 segment display
FPGA: Cyclone II
software: Quartus II 9.0 I have a std_logic_vector number which I want to display on the 7 segment display. meaning: addr_reg: buffer std_logic_vector(log_2_of_num_of_states downto 1); and the attribute was defined: attribute altera_chip_pin_lc of addr_reg : signal is "@V13,@V14,@AE11,@AD11,@AC12,@AB12,@AF10"; (meaning all of HEX0) but when I try to run it, the first hex representation doesn't show any number. I tried fixing it by converting the number to int first, but it still doesn't work and gives an alarming warning. Thanks,1 Reply
Did you convert your numner in the right representation for your 7 segment display? I mean for 0 it is 0000001 for example?
