12 years ago60hz clock for Max 7000s?
Can someone recommend a 60hz clock for Max 7000s?
I was looking to use 555 timer, but I can't get the duration high to match the duration low. Ideally part would be 5v and through hole.2 Replies
If duty cycle is the only concern, what about generating it at 120Hz and divide by 2 using a TFF (input at 1) ?
The TFF can be the Max itself. - Altera_Forum
--- Quote Start --- Can someone recommend a 60hz clock for Max 7000s? I was looking to use 555 timer, but I can't get the duration high to match the duration low. Ideally part would be 5v and through hole. --- Quote End --- Have you considered using a higher frequency oscillator and just dividing that down? Depends on how many LE's you have to spare I suppose. For a 1mhz clock you'd need 1000000/60=16666 = 15 bits. Not ideal but it's available in 5v and through-hole :-) -Mux
