12 years ago60hz clock for Max 7000s?
Can someone recommend a 60hz clock for Max 7000s? I was looking to use 555 timer, but I can't get the duration high to match the duration low. Ideally part would be 5v and through hole.
12 years ago --- Quote Start --- Can someone recommend a 60hz clock for Max 7000s? I was looking to use 555 timer, but I can't get the duration high to match the duration low. Ideally part would be 5v and through hole. --- Quote End --- Have you considered using a higher frequency oscillator and just dividing that down? Depends on how many LE's you have to spare I suppose. For a 1mhz clock you'd need 1000000/60=16666 = 15 bits. Not ideal but it's available in 5v and through-hole :-) -Mux
