5M570ZT144A5 and 5M570ZT144I5
- 3 years ago
Apologize for the delay in response.
As for the differences, it is the same as you read in the datasheet. No other differences.
The FPGA might be broken or not functioning if it is used beyond the exceeded temperature.
Aiman
The following rules generally apply wrt bit-stream compatibility where re-compilation is not necessary :
- You can migrate to the same density device with a fabric speed grade that is faster, i.e. a bitstream targeting speed grade 8 can be configured onto speed grade 7 or speed grade 6 part.
- You can migrate to the same density device with an operating temperature that supports a wider temperature range, i.e. a bitstream targeting commercial grade temperature can be configured onto industrial grade or automotive grade part.
If using an Industrial part with the same or faster speed grade and if operating the device in the Industrial operating temperature range, then they should be able to use the same bit-steam without recompiling.
We would also recommend you to follow the maximum operating temperature as stated in Intel's document as it was tested and proven working. Intel will not be responsible if the device damaged when using exceeded temperature (>100 degrees).
Aiman
Hi Aiman,
Can you help?
