14 years ago32-bit memory with byte access
You can generate a 32-bit memory with byte access using Megafunctions. I like to write Verilog code that Quartus recognizes as a standard megafunction. Quartus has a variety of Verilog examples ...
14 years agoSee the coding guidelines for Q11.1
You need to use SystemVerilog for infered RAMs with byte enable access http://www.altera.com/literature/hb/qts/qts_qii51007.pdf Page 11-30
