12 years ago
3.3V VCCIO for Emulated LVDS (Max V)
I understand how the three resistor termination works to emulate LVDS with the MAX V and other devices that do not have true LVDS.
All of the examples seem to imply that the IO supply needs to be 2.5V. Is there any reason that the I/O supply can't be 3.3V with obvious recalculation of the termination resistors? If recalculation is OK, what is a good value for Zout of the drivers (20 ohms?). I didn't see anything in the datasheet.
Why is 2.5V the preferred choice since most standalone LVDS devices routinely operate with 3.3V supplies?
I can certainly add a regulator but my board only needs two LVDS outputs and it would be more convenient to just use 3.3V for all my I/O.
Thx
1 Reply
    The common mode voltage of 3.3V supplied LVDS_E_3R is oustside the LVDS specification, but it would be tolerated by most LVDS receivers. Ultimately you'll add bias resistors to achieve the specified 1.125 V to 1.375 V output common mode voltage.
    20 ohm is a good guess for driver output resistance. For an exact specification of output characteristic and expectable type variation, refer to to MAX V Ibis files.
