12 years ago3.3V VCCIO for Emulated LVDS (Max V)
I understand how the three resistor termination works to emulate LVDS with the MAX V and other devices that do not have true LVDS. All of the examples seem to imply that the IO supply needs to ...
12 years agoThe common mode voltage of 3.3V supplied LVDS_E_3R is oustside the LVDS specification, but it would be tolerated by most LVDS receivers. Ultimately you'll add bias resistors to achieve the specified 1.125 V to 1.375 V output common mode voltage.
20 ohm is a good guess for driver output resistance. For an exact specification of output characteristic and expectable type variation, refer to to MAX V Ibis files.
