16 years ago2-port RAM
I am beginner of using dual port ram. My write clock is 3 times slower than my read clock? Is it possible to read the correct data from output ram? I would appreciate if you could response me faster. Thanks3 Replies
Just use the megafunction. It will allow you to fully specify the RAM using a GUI. Very good for beginers, and the code works, so no need to build a testbench for the megafunction.
You will need a testbench for your code though. - Altera_Forum
Hi Artem-bond,
Thanks for your quick response. Do you have any simple example for this including the testbench? - Altera_Forum
Yes. No problem. You need dual clock dual port RAM.
