16 years ago2-port RAM
Hello, I am beginner of using dual port ram. My write clock is 3 times slower than my read clock? Is it possible to read the correct data from output ram? I would appreciate if you could...
16 years agoJust use the megafunction. It will allow you to fully specify the RAM using a GUI. Very good for beginers, and the code works, so no need to build a testbench for the megafunction.
You will need a testbench for your code though.
