16 years ago2.5VCCIO and 1.8V logic
Hi, I am designing a board using the EP3C40F324C6N device. The A/D converter that I am using has an LVDS data bus and 1.8V control logic. If I have VCCIO connected to 2.5V (which is require...
16 years ago --- Quote Start --- If I have VCCIO connected to 2.5V (which is required for LVDS), can the same IO bank accept 1.8V logic? --- Quote End --- It could work but you have to keep a few things in mind: - Like Ironmoose wrote: be aware that the output will be 2.5V - The minimum Vih of a 2.5V bank is 1.7V - The Voh of your external device will be close to 1.8V in practice, but your datasheet will probably specify 0.7*Vcc or so. So not enough - A pull-up resistor to 2.5V on the input signals could give these a last step. - The noise margin (difference between Voh and Vih) will be very small - The use of a schmitt trigger input will improve the noise insensitivity Good luck, Ton PS Maybe the bus hold functionality could be use, but I don't have any experience with it
