17 years ago16-bit 4 inputs interfacing with 16-bit 1 input of DCFIFO
hi, i'm thinking to interface these 16-bit 4 inputs to 16-bit 1 input of DCFIFO. i want the data to be written in sequence, starting from Q1 to Q4. when wrreq is asserted in DCFIFO, the output...
17 years agofirst, does the clk input in the packetbitconverter block synchronizes the Q1...Q4 outputs ? (does the Q1...Q4 outputs changes on each edge of clk ?)if yes, then fulldataclk could be connected to clk
fifoclk is the clock connected to the wrclk of the fifo, choose for its frequency, any value that's at least 4 times bigger than fulldataclk (so as to be able to stock all the four values Q1..Q4 in the fifo, before they change)
