chris_gonzalez9
1 year ago10M04SCU324I7G - I/O timing
I would like to know if those values are the minimum, nominal or maximum. Thanks!
KennyT_altera
1 year agoIf you refer to device datasheet, this device itself will not show it is min/norminal/max/ value.
https://www.intel.com/content/www/us/en/docs/programmable/683794/current/fpga-device-datasheet.html
You can refer to https://www.intel.com/content/www/us/en/docs/programmable/683103/21-3/step-4-view-i-o-timing-in-datasheet-report.html
Any reason that you need this value? thanks
chris_gonzalez9
1 year agoHi Kenny,
I'm working on some timing analysis using timing designer and I wanted to know whats the minimum, nom or maximum to set those time constrains in timing designer.
