16 years ago10GbE on 1GbE network
Hi all, Maybe its a beginner question .. :) Can we use a 10GbE board (with 10GbE UDP/IP core) in order to receive UDP packets at 200Mbps rate from an external network ? i mean, is there a...
16 years ago --- Quote Start --- The core needs to be multispeed and also handle 1GbE. The PHY chip will automatically synchronize to the highest speed achievable by the two partners (1Gb/s) so the core must be able to communicate with the PHY at that speed. --- Quote End --- In that case, can the Altera(Startix 4) transceiver in XAUI mode be a good PHY ? I understand that on XAUI mode it cannot work less than 3.175Gbps. right ? Shalom
