16 years ago10GbE on 1GbE network
Hi all, Maybe its a beginner question .. :) Can we use a 10GbE board (with 10GbE UDP/IP core) in order to receive UDP packets at 200Mbps rate from an external network ? i mean, is there a...
16 years agoNo, you will only gain some latency if both ends are at 10GbE. If your network is 1GbE anyway, you won't gain anything with a 10GbE board. A converter would only add more latency.
