XZilo
7 years ago10AX066 A10 FPGA transeciever calibration problem:PreSICE nerver relese internal bus
A10GX series FPGA: Manual xcvr_phy said that transeciever must have a clock before loading the program, otherwise it needs to recalibrate transeciever, but I encountered a problem when performing JES...
Deshi_Intel
7 years agoHI,
May I know do your issue recover after you perform another round of transceiver reset to trigger the calibration process again ?
There are couple of reasons that may affect transceiver power on calibration
- DO you have free running 100Mhz-125MHz clock source supply to FPGA clkusr pin ?
- Do your Quartus design contains PCIe ?
- https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2016/why-doesn-t-the-gen3-stratix-v-pcie-hip-start-flow-control-initi.html
- Do your board system level trigger FPGA transceiver channel reset in the middle of transceiver power on calibration that may screw up the calibration process ?
Also, what's the status of CDR lockedtodata signal ? Is it asserted high ?
dlim
