Why Arria10 doesn't support "incremental compiling" in Quartus Pro 19.2
- 6 years ago
We are doing some migration work, so the subscription might not ready. I will check internally.
Can you upgrade to latest release 20.2? If no, you will have to use command line to run the rapid recompile.
Put this to test.tcl and run it with quartus_sh -t test.tcl
load_package design
load_package flow
project_open Test
execute_flow -compile
#execute_flow -recompile
#execute_module -tool fit
#execute_module -tool sta
project_close
Rapid recompile is should be supported in Arria 10 device. May I know which version that you were using? I tested it in Q20.2pro edition and it is working. Also, you need to turn on enable intermediate fitter snapshots to use this feature.
To reduce the compilation time, you can refer to https://www.intel.com/content/www/us/en/programmable/documentation/zpr1513988353912.html#mwh1410471192919 -> 2. Reducing Compilation Time
If you were using signal probe for debugging, you can refer to https://www.intel.com/content/www/us/en/programmable/documentation/cxt1478215337364.html
I had "subscribe to board" in top-right down menu, but I didn't receive the reply in my registered email ? It's strange ~
Hi @KennyTan_Altera , I use "Quartus Prime Pro 18.1" .
