ARey0's avatar
ARey0
7 years ago
What is the difference of stability between reference clock and output clocks in a PLL?
Hello
In my project I need a frequency of 250 MHz and ±10ppm of stability as minimum, also I need two of this frequencies with 90 degrees between them.
I have thought to use a PLL with a reference clock of 25 MHz and ±10ppm to generate both frequencies. Hence I have some question:
  • Has a PLL the same stability as the reference clock, in this case, ±10 ppm as minimum?
  • In other words, what is the difference of stability between reference clock and output clocks?
I am interested especially in the long term stability.
THANKS😀
1 Reply
