SSnyd4's avatar
SSnyd4
6 years ago
We need to replace an ACEX 1K FPGA model EP1K100. The suggested replacement for ACEX 1K is the MAX V; however, the MAX V only has 2210 LEs which isn't enough (EP1K100 has 4992 LEs). The MAX 10 is a better match. Is this an appropriate choice?
Here are the requirements base on our compiler results:
  • Family - ACEX1K
  • Device - EP1K100QC208-1
  • Timing Models - Final
  • Met timing requirements - Yes
  • Total logic elements - 2,440 / 4,992 ( 49 % )
  • Total pins - 132 / 147 ( 90 % )
  • Total memory bits - 23,808 / 49,152 ( 48 % )
  • Total PLLs - 0 / 1 ( 0 % )
We will be revising the PCB to accommodate the new FPGA, but we'd like to use the same FPGA firmware if possible with minimal software development required.
  • SSnyd4's avatar
    SSnyd4
    We're using Quartus II 9.0sp2 Web Edition. There is very little custom code and most of the design is using the MegaWizard Plug-Ins. I reviewed the other FPGAs and the MAX 10 and Cyclone 10 seem like the best fit. The Cyclone 10 has a lot more LEs and more capability that we currently require, but might be a good fit for our next generation product which we will be developing in the next couple of years. Right now our requirement is a direct replacement for the design based on the ACEX 1K.
